I wanted to know if updating the drivers for your sound card is as important as drivers for your video card? I keep my video card drivers up-to-date but the sound card is a different story since I don't know if they exist or should be updated for that matter.
I have a factory provided sound card right now and I believe it is from Avance Logic Inc. But if you do update the sound card drivers, where do you go because the Avance Logic site isn't really easy to understand and I don't know which one I am supposed to download for my system.
This isn't really crucial but I wanted to know what you guys think about it.
HP wasn't very helpful either. LOL!
My rule with drivers is to never update until i have an issue. Had too many cases of a new driver making no improvements to anything, but causing problems elsewhere. Biggest example of this was my old capture card. Installing -any- newer driver than the bundled one caused it to stop working. even installing a newer version of DirectX stopped it working!
If it aint broke..... -
If it ain't broke, don't fix it. I am still running a very old Win98 release on my kids computer for that very reason.
Talk about an unexpected issue. I downloaded the DirectX SDK, and now occasionally, my TMPGEnc throws an ASSERT. I fear somehow I have register a debug version componant. But, that's OK. I'm not even going to attempt to fix that until I have a more severe problem.Just what is this reality thing anyway? -
I updated a lot of my drivers when I changed from 98 to XP, but I would not change the drivers just for the sake of it.
If the sound is fine, then don't fix it.
Microsoft have been recommending a sound card driver update for sometime on my computer and I ignored it.
I am also getting the same recommendation for the modem, again I ignored it. Better for me to keep using Compaq's modem driver, not Microsoft's.
These updates from Microsoft isn't always the best and in some cases makes it worse. They aren't important or critical anyway.
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 09:13 -
Does your sound card need drivers to use optical output?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 24th Feb 2009, 13:39 -
drivers
By Mr anderson in forum ComputerReplies: 2Last Post: 29th May 2007, 04:36
