Hi,
I am trying to backup a DVD with LPCM audio but audio is missing in the
final product. The reason I am doing the following procedure is because
it was suggested that if I convert LPCM audio to ac3 audio, I can save
a lot of space which can be used for video. The following thread has
this discussion: https://www.videohelp.com/forum/viewtopic.php?t=171277
The procedure I followed is:
1. Ripped the movie as a single vob file using SmartRipper.
(First, I ripped in stream processing mode but it created to video
files and one audio file. So, ripped the movie again by creating
a single vob file)
2. Demuxed unsing TMPGenc (used MPEG Tools -> Simple Demux)
and got one video and one audio (.WAV) file.
3. Followed Baldrick's guide to convert WAV to AC3. In BeSeet I used
Endian-Motorola, 48KHz, and 384bits.
4. Used TMPGenc DVD Author to create DVD files using video file in
#2 above and audio file in #3 above.
5. Used Nero to burn on to a DVDRW.
My dvd player is Apex AD1500. I also tested with PowerDVD in my pc.
There is no audio.
I did some search on these forums and multiplexed video and the ac3
audio using bbMpeg. The mpeg that was created has audio when I played
it on my pc. But if I create DVD files using the same mpeg file in
TMPGenc DVD author, againg there is no audio.
Appreciate if anybody can tell me what I am missing here.
Thanks.
I tried ac3fix and it said there are no errors in my original ac3 audio file.
If I play just the ac3 audio file, it plays fine. Only if I multiplex it with
TMPGenc DVD Author, the audio is missing. Any thoughts?
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
Vob2mpg audio missing
By LSBREWER in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 14th May 2011, 09:24 -
Am I really missing anything from not having an hd audio capable amp?
By yoda313 in forum Off topicReplies: 1Last Post: 23rd Dec 2010, 16:59 -
PIP Missing audio
By john920 in forum Blu-ray RippingReplies: 0Last Post: 22nd Jan 2010, 22:02 -
Partially missing audio
By DEMNz in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 18:15
