    Feb 2003
    Newcastle Upon Tyne UK
    I drag the dvd image into the place in 42 and let it do its stuff, when I get to the burn what's in here folder part they are always empty.
    i really want to learn how to back up my dvds onto svcd but I am having no luck. Can anyone help??
    Many thanks
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Are you using the latest version of Forty-Two?
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Feb 2003
    I have version 1.6, I watched the process and as it finished it deleted the files it had created. When the video is xferring it doesn't show the time at the top, it goes to the this takes a while version????
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    1. try to keep your posts together. no need to make a new post like the other one I replied in.
    2. check my reply in your other post. and let me know
    3. it does take a while. how long did it take? what speed is your CPU?
