I'm a newbie. I have been able to rip some DVDs to VCDs using DVDx and VCD Easy to burn such to disk.
I am having problems with the only DVD I'd really like to rip, "King of Masks," a Chinese DVD. It's single layer; language; and the subtitles are on screen all the time. It's part of the video.
The trial version of WinCopyDVD will rip the first five minutes. It took a couple of tries and rebooting. So apparently, this thing does rip.
I'm trying to use DVDx to rip the movie. I get two errors:
After I close the input setup: MPEG2Dec. Error during decoder installation.
When I try to record: Decoder not initiated. Open an IFO/MPEG file first.
When I go back and attempt to set it up with the VTS 01 0 IFO file, I get the same results.
What must I do? Thanks in advance.
The movie I wanted to rip has permanent subtitles and only a single language. I was able to rip with EasyVCD, encode with TMPGEnc (which popped up automatically in using Easy VCD), and burned with VCDEasy. The results played just fine on a stand alone.
My daughter has a cheap Cyber Home DVD player which allows VCDs to zoom OUT (or make the picture smaller). The slight shrikage really gives a sharp picture.
Some movies are stubborn lately
By dougworm in forum DVD RippingReplies: 2Last Post: 25th Dec 2009, 02:40 -
Stubborn AVI files arent working!
By miiitchhh in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2009, 23:11 -
Looking for some help removing stubborn Trojans
By RKelly in forum ComputerReplies: 14Last Post: 12th Oct 2008, 18:46 -
Divx problems......how do I fix a "stubborn" file?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2008, 20:34 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 03:39
