on some dvd's when i rip them (using smart ripper), then take them into dvd2avi, it creates the project file, but no wav file.
only on certain dvd's (almost famous and castaway)
thanks,
p_Dog
On dvd2avi, try selecting a different track number under audio. That should do the trick. I had the same problem but when i selected track 2 instead of track 1, it created the .wav file. Does your tmpgenc read the .d2v video file. Mine for some reason says that the file is not supported. Please help.
ccngo, i pasted this from another topic i posted in:
1. in the folder where the dvd2avi proggie is located, u need to put a file called DVD2AVI.vfp. when u run dvd2avi, goto "help" and make sure u check "VFAPI Plug-in."
i had a 2. and 3. but if u need more info u can take alot on the other topic
Question about sound
By slaughteraus in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2011, 01:51 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
Sound problem question
By mysts in forum ComputerReplies: 3Last Post: 20th Apr 2009, 14:13 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
