I am new to this conversion. I have a few questions if anyone would like to give me some thoughts...
My System:
Dell Inspiron 8000
Pentium III 800
256 MB RAM
Windows XP
10 GB Hard Drive, 2 GB Free with already DVD Ripped
Ok, I'd like to port this DVD (Sphere, 135 minutes) to DivX. I am following the guide at http://www.divx-digest.com/articles/dvd2divx4_flask.html to encode the DivX using FlaskMPEG.
I am croping the back strips so the picture is 480 x 208... is this ok? Do I leave Frame Size at 480x480?
Using DivX 4.01, I started to encode last night... it projected it would take about 8 hours to complete the full movie.. Is that considered a long time?? Is there better (or faster) program to do this with??
Thanx...
i had sam problem all the guides suck for beginers because if you already have the programs their probably not set up right with the pluggins .i liked the articles at the doom9 site. download their packs .im using a dual p3 system with 1 gig of ram and i did my first movie with out putting any filters or whatever the basic was. it was 60 minutes and took 3 hours ,but i dont think the duel p3 work at their max it needs to be in the software.
Muzicman82, set the resolution to 640x368 and crop it to 640x272, it will look alot better then 480x480. Divx4 is not as fast as Divx3 so 8 hours is about right. The fastest Divx encoder is MPEG2AVI but its a lot more complicated then FlaskMPEG.
muzicman,
i would seriously suggest you use vidomi to encode your dvdrips to divx. its sooooo easy to do it with this program, you just load the .vob files, and it does the rest for you.
you can find it at http://www.vidomi.com
you can also use 2 pass vbr and it will give you results as good as nandub.
it is a really really great program.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
