When using TMPGEnc's Project Wizard to creat SVCDs, are you suppose to match the template based on the *source* material, or is it based on the *output* you wish to produce? Would you select the PAL template when the AVI you're converting is 25 fps, or when you wish to produce a mpg that runs at 25fps? If it's based on the source, then how would one go about converting from 25 -> 23/29?
Related issue : what template would one use when trying to convert from 24 fps to standard NTSC (23/39)?
Thanks in advance...
The settings define what the output will be.
PAL to NTSC is not trivial, there is a guide for that. -
You need to try harder. I just found 2
here's one
https://www.videohelp.com/guides.php?howtoselect=4;41 -
Originally Posted by ChorazaiM"Art is making something out of nothing and selling it." - Frank Zappa
FYI the general idea is to take 25 fps video,
appy pulldown as if it was 24 fps film to convert
it to 30 fps. and resample the audio to match.
It will play 4% slower after this.
24 fps movies are regularly aired in Europe at 25 fps -
Originally Posted by FOO
So what would you recommend I do with a source file that has a 24 fps? Lots of guides on how to do PAL->NTSC, NTSC->PAL , but what about 24fps files? Should I try to convert them to 23 and have a pulldown, or encode them right to 29? And suggestions?
So what x264/MeGUI settings will Adobe Encore ultimately like?
By Asterra in forum Video ConversionReplies: 28Last Post: 16th Dec 2011, 14:40 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
Tmpgenc Xpress 4 : any PS3 templates?
By lapino in forum Video ConversionReplies: 0Last Post: 12th Mar 2008, 08:34 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
