Is there a program that can do this with out the final product looking junky? I used DVD WorkShop and if you capture in AVI then convert to MPEG it isn't a problem, but it gets shakey and smudgy when there is movement on the video if you skip the AVI step.
Dorian
ATI capture cards do a pretty good job.
There's a PVR-250 that does it in hardware.
<- Look in the capture cards section.
Pure sofware solution depends on your card and computer -
I have tried it a few times with MF2 and the results were very good.
SLICK RICK
Originally Posted by lordsmurf -
What hardware are you capturing with?
SLICK RICK
Your Canopus is a DV device. Not sure if it can even do anything other than AVI.
If you've got a fast enough PC several programs can do this. I use neoDVD and Virtual VCR. I capture my LD and VHS tapes to 352x480 MPEG2 and then just author. The quaility is slightly lower than if I captued uncompressed (or huffyuv) then encode with CCE. But it's much faster and the time vs. quaility trade off is within my acceptable limits.
Real-time analog to DV capture - what is the right device to use?
By Serge_KB in forum Capturing and VCRReplies: 16Last Post: 24th Apr 2012, 13:33 -
Real time video capture/display software?
By TheDunk in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2012, 23:16 -
How to capture real-time video from my camcorder onto my PC
By seanhalley in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2011, 05:37 -
FlYDS capture REAL-TIME MPEG-2
By goal in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2008, 05:08 -
Capture in Mpg Real Time-Best settings?
By themaster1 in forum Video ConversionReplies: 3Last Post: 21st Jun 2007, 22:01
