I have not been able to convert to mpeg 2 properly since i got my Asus 0402p DVD burner.
No matter which codec i use huffyuv picvideo morgan even uncompressed
I get wavey lines on my encodes especially when scene change or high movement. I have used different field order and lots of other various combinations..it has blown my mind I had it worked out using morgan than last night i upgraded the firmware and now i can't encode from any avi codec without this error...Wmedia player plays the file fine Power dvd shows the error ..standalone dvd shows error i have done test on various clips frameserving with avisynth going to all types of specs same problem
Any suggestions
Results 1 to 11 of 11
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
Don't quite think I can help with your problem - but on a side note I tried finding your mp3s on your web site but it says Under Construction
Thanks anyway i am begining to beleive that i might have a conflict between my mobo (via) the burner and the software....
My site is still under construction as i had to complete it for an assignment and keep it in the conforms now that it has been marked i have to find time to re write it and make a kick arse tekno site...dedicated to electronic music ,....mostly teknoHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
more info
have an
Asus DRW 0402p DVD-r burner
Via chipset Celeron 1.1 ghx
Leadtek A170 vivo graphics card
650mb ram
Problem:
Ever since i got my burner all my avi encodes to mpeg 2 have been all wavey and messy on major scene cahnges and high movement.
I have tried several encoding apps frameserving with avisynth.
I am able to load the file directly into tmpgenc and let that program do it all with no problems however it adds 20 hrs to the encode.
I have used many settings when capturing the file many different avi codec eg Pcivideo morgan mjepg huffyuv even uncompressed avi everytime it is framserved this problem occurs.How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
I have tried resizing in many different ways ...I have used avisynth now for about 8mnths with no probs now ...it doesn't work...I will have to use tmpengc for the whole process....until i work it out
Ohh another weird thing that has happened since my burner has come in is when i record in vdub no sound is played thru...it is record fine now problem but when capturing ....no sound....weird
Did you install any new software with your burner? If so try uninstall it or make a system restore to a point before the burner was installed. Sometimes one software can affect other in most strange ways. For instance when my girlfriend installed Ulead DVD PictureShow 2 all her system sounds disappeared, but it was solved with a patch from Ulead.
Have you tried to remove the burner? Maybe there is a hardware problem?Ronny -
I have tried that but now i all the system point to that hardware it's hard to change back unless i reinstall without the burner. I haven't installed any software that cause problems i initally thought it was the dvd authoring software but it is not
Are you saying that you were able to capture without problems, with the same hardware, and the ONLY change made was to install the DVD burner? If so, the obvious answer is to uninstall all software and drivers associated with the burner, re-install original codecs and software, and physically disconnect the burner, both power and data cables.
If this does not immediately solve the problem, be certain you have re-installed all software, drivers, and codecs. You need to get back to a working baseline. Create a system restore point when this has been acheived, NAME IT, and save it twice.
Once you have got the system working, physically connect the burner, data and power, but do NOTHING else - NO SOFTWARE. Test. If this works, then load the software and the problem should re-occur. If you're still OK, then some sort of corruption occurred during install. If it is the software, DL the latest versions or try something else. If it's the burner itself, return it as defective.
Is the burner by any chance on the same IDE channel as your capture drive? If so, seperate it. Test as above first, then add moving drive to other channel before burner software re-install. -
they are definatly not on the same ide channel. that is a fair enough test one that needs time to do ....i suppose that is the best way to go ...when i get some time thats what i will do thanks for the advice.....
Wendy's just beat Burger King for #2 (USA market).
By edDV in forum Off topicReplies: 7Last Post: 22nd Mar 2012, 18:35 -
What was the last video game that you beat?
By yoda313 in forum Off topicReplies: 21Last Post: 29th Sep 2010, 14:50 -
Unable to beat Netflix, Blockbuster swats at GameFly
By stiltman in forum Latest Video NewsReplies: 4Last Post: 11th Aug 2010, 11:34 -
Go Canadiens! Beat the Pens!
By yoda313 in forum Off topicReplies: 0Last Post: 12th May 2010, 20:25 -
Realtime Slideshow sync to music beat
By P_Cherry in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2007, 02:59
