OK ive tried numerous guides and programs to do this but it just doesnt work.
Firstly i had some success with this method but now it doesnt make the movie properly, when i merge the files, the whole movie isnt there, or some of the sound disappears.
Ive used isobuster to get the mpg files from cds, merged them in tmpgenc merge+cut, then tested to see if the whole movie merged which doesnt seem to happen anymore, then if they worked id run them through simple demux, then run the audio through besweet, then use ifoedit to dvd author the files.
Another program i have tried is svcd2mpgdvd+, this just says it is converting the audio for over 4hours and shows no hard drive activity so i guess it doesnt work.
Also tried ulead movie maker but when i start creating dvd files from my mpgs it says that it will take over 9hours or something, and im not sure if this program converts the audio anyway.
I thought the first process using tmpgen was great until it stopped converting my movies, i had some success but not anymore.
Does anyone have any tips for me or some guaranteed methods that work?
I would try re-encoding your movies separately.
There is no need to join them first.
The Authoring process will stick them together. -
I demux'd one cd and it worked ok, but when i did the 2nd one it made files that were about 1mb so it definitley failed on demux that mpg file.
any ideas about this?
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17
