  1. Hi there,
    Im running WinXP and have dloaded latest version of TMPG. When I am trying to convert the movie and I attempt to add the relevant file it comes up with an error message "Can't load P3Package.dll". Does anyone know a way around this?
    Thanks in advance
    ivxample
    ontario ,canada
    Reinstall the program.I've had this happen before.
    bmiller,ont.canada
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Here's a quote from a list of common TMPGEnc problems:
    "If TMPGEnc says Can't load P3Package.dll?
    Be sure that you have exctracted all files in the tmpgenc zip file to a folder then go to that folder and start tmpgenc.exe or make a shortcut to tmpgenc.exe and it should work."
