  1. Theres a program (i forgot what it was called) for regular cd-r/rw's that can tell you what brand it is, speed it can burn at, etc. Im wondering if thres a program out there that can do the same w/ DVD media. Im curious because some company's just buy the dvd's from another company and just make their own tops. Like HP or Fuji cd-r's dont make their own cd's the cd's are actually Taiyo Yuden's (last time I checked).
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Look here, there is also another called advdinfo out there that does the same thing.
    https://www.videohelp.com/forum/viewtopic.php?t=150044
  3. www.dvdinfopro.com
    Features in DVDINFOPro™
    Complete new look, complete new GUI
    NEW CD/DVD Speed & Error Test functions
    New Snapshot to jpg and clipboard copy functions.
    Expanded Drive & Media Info sections.
    Recognition of DDCD, HD-BURN & Mt Rainier technologies
    Media Info show UDF information controllers and drives
    New “Send Custom Command” feature, send your own commands.
    Over 80 build in command templates for custom command function.
    Expanded Advanced Command section.
    New slide-out, slide-in command dialogs.
    New “Read Blocks’ function reads consecutive blocks quickly
    New “Complete Media Code” shows the media code block.
    Quick Erase & Fast Format supporting DVD-R/RW & DVD+R/RW.
    Optional program logging.
    Unencrypted VOB, MPG, AVI (etc) player with sliding video window.
    Now compatible with Windows 95, 98, ME via ASPI.
    SPTI for Windows NT, 2000 or XP. (admin access needed)
    External USB, FIREWIRE drive support on Win2k and XP.
    DVD maximum speed now shown under media option.
    Digital status display with colouring choices.
    Check for program update on web feature.
    And More...
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
