I have a collection of TV shows that were cap'ed for me using TIVO. The AVIs were 576x432. This seemed odd until I relized that TIVO cut out the overscan area. Add borders (24 top and bottom, 32 right and left) you end up with 640x480.
Now what would be the best method resizing?
Up sizing to 704 or downsizing to 1/2D1 (352x480)?
The shows are pretty good quality, better than VHS even with some of the compression.
If you want to stay better than VHS, I would recommend upsizing to 704x480... but not 720x480. If you don't mind a slight loss in resolution, then 352x480 should be just fine.
Darryl
What's the best way to Convert 704 to 720? Avisynth or otherwise
By VideoFanatic in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 03:19 -
720 x 576 (2703kbps bitrate) AVI for Archos 704
By drstew in forum Portable VideoReplies: 10Last Post: 31st Aug 2008, 14:49 -
704 vs. 720 burn to DVD
By brstephe in forum Authoring (DVD)Replies: 20Last Post: 11th Dec 2007, 13:16 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 11:33
