I was curious about any sound editing tool to help clean up the sound from files with MP2 and MPA extensions.
SoundForge 6 using the MainConcept MPEG Audio plugin.
Thanks for your quick and concise reply. I was in a toss up between Sound Forge and Cool Editor. Thanks!
lordsmurf.com will have audio restoration guides by the end of the month.
Well after getting Sonic Forge 6 started. It seems I am running into trouble opening the codec for the audio. I also noticed earlier you said to use the Main Concept Audio Plugin. Is that a stand aloneprogram or something within Sonic Forge 6?
cleaning dvd's
By the_shyguy in forum MediaReplies: 25Last Post: 7th Dec 2009, 05:39 -
Cleaning a DVD??????? Best way???
By vbond0071 in forum Newbie / General discussionsReplies: 19Last Post: 24th Mar 2009, 19:33 -
Cleaning the lens?
By Digiface in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Sep 2008, 11:27 -
I need some help cleaning up Audio.
By efb91 in forum AudioReplies: 1Last Post: 22nd Sep 2007, 14:28 -
Cleaning a sound file
By jimcgr in forum AudioReplies: 11Last Post: 2nd Jul 2007, 01:09
