  1. is there a way to insert a subtitle to an avi and comperresed it toghter ?
    becouse when i tried to use a "normal comperresion" on the video select
    the filters menu as unable to select.
    is there away to use the filters and use th enormal compresion ?
    Apr 2002
    The State of Frustration
    You can load your video, add your filters, and select compression-->No compression. Or just use a codec.
    Hello.
  3. i guess you didnt anderstand me.
    i want to add permannet subs to an avi.
    when i use the no compresion the goes to 7 giga.
    i want to use the filters and get a normal file like 700 mb.
    is there a way to use vdub, add filters and subs, and use the comperssion
    to get a file about 700mb ?
    Apr 2002
    When I said use a codec, I meant when you have configured your subtitler, select Video-->Compression-->Huffuv (for example).
    Hello.
  5. sorry about the mistake.
    thanks for the help
