First time its happened, but when transferring Head of State DVD-Rip to DVD-R, the audio is ahead of the video. The original svcd's play faultlessly.Anyone got any suggestions plzzzz ?
cheers
tophope
tophopeGuest
Read this guide: https://www.videohelp.com/forum/viewtopic.php?t=161658
Greatings,
Yf -
HiAllGuestI have exactly the same problem. The link that Yf is giving, applies to captured tv programs. My source is directly from a dvd.Originally Posted by tophope
I didn't found a solution eighter. Strange thing is, it doesn't apply to every movie. So this link is not the right way for me, because I don't know, if I have to re-encode or not. (I rather not) When I have sync problems it seems to be consistent that the audio is about 100 mSec off. 0,1 seconds seems nothing, but I tell you, it is very annoying. (Like to have some feedback if more people are looking at the same value)
After a lot of searching, I still didn't find the cause.
The way I resolve this issue now, before I find a better way:
1. Use SVCD2DVD+ to rip the bins and demux the streams.
2. Import the elementary streams in DVDlab, and compile the dvd, without burning. This takes about 10 minutes.
3. I open the VOB files and watch part of the movie in PowerDVD, to check if I have sync problems.
4. If there is no sync problem, burn it.
5. If there is a sync problem, re-encode the audio stream with a delay of minus 100 mSec in DVDlab. (takes 10 seconds) Import the new audio stream and compile the dvd again without burning.
6. Go back to step 3.
I don't know if other authoring software have the same option to delay the audio.
This works for me, but if somebody knows a better way, please let me know.
TIA -
The problem isn't only tv shows.. the problem is mpegs in general if you got your hands on a not complete (even when you can play it with you player on your computer it will not tell you if the mpg is complete). I don't have any problems with mpegs i encode myself what ever source they come from i have problems with mpeg i get over the net from friends. If it isn't complete finished getting to me then when you demux the audio it will be off in what ever author program i use..
Greatings,
Yf
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
Delaycut question about 6 chan ac3 out of sync when 2 chan is in sync
By B2K24 in forum AudioReplies: 3Last Post: 27th Apr 2009, 17:10
