I have a wintv-pvr250 with an onborad hardware mpge2 encoder. Is it possible to route an avi file i have on my hdd throuth the encoder to produce the mpeg2 file? If so, how?
Thx,
Rod
You could copy the AVI file to a DV camera, then feed that back through the card capturing in MPEG2.
Otherwise, all the encoders that I know of are software MPEG2 encoders and do not use the hardware MPEG2 chipsets in any way. -
No you can't. Even friesr's methode is not really a good way to do it. The PVR-250 has only analog inputs, so you would be going digital to analog and back to digital. You'd be way better off using a software encoder....
Good point... I had not thought of that!
Then my question is what type of time frame should i be able to conver a 1hr video? I have an xp2000 with 512 and it seems to take 4hr per hour of video to encode it. Is there a faster way? Something that is 1:1 or better? -
Woops I meant andkiich's methode.
4 hours isn't bad. From what I have found faster encoders = worse quality
I use TMPGEnc with 2-pass vbr encoding and it takes about 3-4 hours for an hour of video on my 2.0GHz P4
You can use CBR and cut the time in half, but you have to encode at a higher bitrate to get the same quality and your final file size will be bigger.
I have another encoder that came with my DVD burner that can do it in real time, but the output quality is junk.
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 10th Apr 2010, 00:32 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 20:51 -
WinTV Hardware Encoder Workflow?
By Armandoban in forum Authoring (DVD)Replies: 5Last Post: 23rd Sep 2008, 14:42 -
ripped dvd's to avi, which route?
By ojfish247 in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2008, 20:21 -
Best hardware mpeg2 encoder (under 700 $)?
By Speed Demon in forum Capturing and VCRReplies: 27Last Post: 6th Sep 2007, 11:01
