I've got my raid 0 array divided into 4 partitions with one partition dedicated to vid capture and another for where I store encoded video. I was wondering if it makes a difference in speed working with two partitions rather than just one. Would it be faster to store and encode video on just one large partition? Thanks.
It's generaly best to capture to another physical hard drive. The raid is fast enough by itself, so I do not see any benefit of creating partitions as they are really virtual drives, not physical. I have a 250 GB raid 0 and have captured MPEG2 and uncompressed AVI and have had no problems.
I can see you running into some issues if your capture is running long and you run out of space on one of your partitions. Really, I only see a downside to having the multiple partitions. -
Since raid treats the two hard disks as one, I thought reading from one partition and writing to another at the same time might be incurring a performance hit. Does the raid 0 compensate enough for the hit?
Do partitions on HDD slow down performance ?
By Noahtuck in forum ComputerReplies: 20Last Post: 19th May 2014, 10:33 -
HDD Partitions question.
By SE14man in forum Newbie / General discussionsReplies: 13Last Post: 24th May 2011, 14:32 -
FFMPEG -partitions
By Klagar in forum Video ConversionReplies: 0Last Post: 4th Oct 2010, 11:12 -
partitions
By jyeh74 in forum ComputerReplies: 11Last Post: 1st Jul 2009, 22:33 -
Join two partitions
By Jomapil in forum ComputerReplies: 5Last Post: 11th May 2009, 16:28
