I'm trying to make a DVD with only Music. I'm not sure if I should use WAV. files or AC3 files to do this. I'd appreciate any help! Thanks in advance. :P
You can use either, one is compressed the other is not. If you want to fit more on the disc, then go with AC-3 as it is the compressed format. I after you have all your music and everything will fit on one disc, then save yourself the hassle of a conversion step and leave them uncompressed.
Read up on AC3 audio here:
http://yunus.hacettepe.edu.tr/~bbm891/AC3/AC3.html
I don't know that much about Audio DVDs, but I would choose AC3 due to it's good compression and the fact that it can handle mulitiple channels of audio. -
Read up on AC-3 and did exactly what you both said... It worked out great and already made a Audio-DVD. I honestly didn't believe anyone would help tho it shows there are some great people out there. Thank you again!
Newbie question for creating a DVD
By DaBooch in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 18:51 -
Zealsoft Music DVD Maker question
By mysts in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2008, 08:33 -
newbie dvd menu question
By mikeoliver1313 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2008, 06:05 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 20:08 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16
