what is the best results i can get from that list :
CCE
TmpgEnc
proCoder
Mainconcept
the fastest is mainconcept but i cant framserve to it to use subtitles..
CCE is fast but version 2.5 cant load vdr files of Vdub and if i convert it to a fake avi file the frameserve not working..
proCoder is good i can use subtitls with vobsub but it is slow...with 2 cpu
vbr 2pass avrg.5500kbps is 10hr!!
tmpgenc is nice but the quality of the mpeg2 encoder is not good as CCE or procoder...
so, maybe one of you know how to frameserve to mainconcept or cce and using subtitles...?
thanks
I only use CCE and MCE with AVISynth or VDub frameserving. CCE 2.50SP is a little unstable with VDR or AVS files. Sometimes you can't drag and drop your file into CCE. The way to work around this is to edit ECL file. Open a working ECL file and replace original source with your VDR or AVS file, save it and open it with CCE. If this doesn't work for you, I have no idea why. Perhaps you should upgrade to CCE 2.67, which officially supports VDub and AVISynth.
On my computer, MCE 1.31 just won't take AVS file. I have to wrap it with Link2 AVIWrapper in order to frameserve. Maybe you can give it a try.
Procoder is painfully slooooow and almost useless, IMO.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
TMPGEnc XPress 4 seems okay, will ProCoder do this better?
By tluxon in forum Video ConversionReplies: 2Last Post: 14th Apr 2009, 18:16 -
CCE, Procoder, Quenc or HCEnc: which one do you get better results?
By devilcoelhodog in forum Video ConversionReplies: 28Last Post: 31st Jan 2008, 21:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
