What is the best procedure to follow and software to use to convert Divx/Xvid movies with MPEG Layer-3 audio to DVD. I have been doing the following but am experiencing audio synchronization problems:
According to instructions on this website I have been performing the following steps to convert Divx v3 MPEG4. Divx v5, & Xvid MPEG4 video all coupled with MPEG Layer-3 audio to DVD for viewing on my home surround system:
Using Virtualdub, I extract the audio to a Wav file. Using TMPGEnc, I select CBR MPEG-1 Layer II audio (MP2) format, then select the source file; for video-movie.avi; for audio-movie.wav that I had created from Virtualdub. I then complete the process and encode the movie to the MPEG format. I then use Ulead Movie Factory to create the DVD. I have had success following this procedure only once. The video and audio was in sync, but the movie played with Dolby-Pro-Logic sound.
All other attempts using this conversion process has resulted in audio sync problems where the sound lagged behind the video. The time delay was constant throughout each movie.
Following instructions on how to correct audio sychronization problems, I ran into further problems with Virutaldub or Sonic Forge not allowing me to open an MPEG file so I could demultiplex the video and audio and fix the problem.
WHAT IS THE BEST PROCEDURE AND SOFTWARE TO USE FOR THIS CONVERSION PROCESS? HOW CAN I CONVERT THE MOVIE AND LISTEN TO IT ON DVD WITH DOLBY DIGITAL 5.1 SOUND.
Your help on this matter will be greatly appreciated. Thank you.
Results 1 to 1 of 1
Sincerely,
VPM
Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 20:20 -
MPEG-4 (DivX & XviD) movie discs no longer recognised by players.
By Sproggins in forum Newbie / General discussionsReplies: 11Last Post: 6th Sep 2009, 16:09 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
Converting Dual Layer DVD to Divx/Xvid
By Snorph in forum DVD RippingReplies: 8Last Post: 15th Mar 2008, 17:37 -
AVI files - MPEG Layer-3 - audio conversion?
By ChoonyFish in forum Video ConversionReplies: 6Last Post: 7th Feb 2008, 09:27
