  1. Ok I'm using Easy CD Creator 5 Platinum, and it;s just like on the web pages, some of my mpegs go in alright, but some I get error message saying it isn't a valid type, now I've tried all that fixing mpegs etc multiplexing and de. It plays fine in WMP and Morpheus but wont go into EZCD. Any one got any ideas where I might be going wrong?
    Cheers in advance.
    Nick.
  2. Banned
    Jun 2001
    UK
    Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
    Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
    For Easy CD Creator to except those VCD.mpg's they MUST be 100% compliant. If you have a mpeg with anything different from above it will not except them.
    TMPGEnc has templates that you can load, to convert them to compliant VCD's
    There are some programs that allow you to ignore the warning "Nero" but doing so could render the VCD scrap, if not on your player but on somebody else's.
    Try to make your VCD's as they should be made
    _________________
    ______
    <font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-10-01 16:08:24 ]</font>
