I am unable to play any vcd's in this Hitachi DV-P415U. The information on this site says they are compatible with all types of cd-r's. Any suggestion as to why this player won't play vcd's it would be appreciated.
I downloaded them from the internet and burned them. Is there a way to identify how they were authored. Or can I change their current format?
Thanks for the reply -
So you d/loaded a premade MPG file and burned it. How did you burn it?
You can't just burn the plain MPG file onto a CD and play it. You have to create the proper VCD dirs and convert the MPEG to a DAT file. Nero has a template to do this. OR you can use VCDImager to create an image of the MPEG, and then burn that?
Need help with Hitachi DV-P323U
By G1Convoy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 30th Oct 2011, 23:27 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Help: Hitachi DVP425E
By music_freak in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Apr 2009, 14:36 -
Hitachi AX-M79
By LiamA in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Feb 2009, 13:55 -
Hitachi DZ-BD70A
By Red Hat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Oct 2008, 07:48
