  1. i wanted to know if its possible to make a VCD/SVCD of a DVD that has all the deleted scenes in it, the DVD has bonus deleted scenes and i wanted to know if i can include them in the VCD/SVCD i will make, so it'll be like one big movie and has all the deleted scenes in it. that would be very awsome if i could do this.
    THANKS
  2. Yeah, it can be done. You'll have to use a video editing tool to chop the movie up into pieces and then merge them all back together again.
    There are many guides describing how to do this and the tools needed.
    Guides here.
  3. i dont see any guides for this, can u direct me in the right direction?
    THANKS again
  4. In the guides, there is a drop down list "How To Category". go down to EDIT. Under that there are 2 selections for "How to cut/join/edit...."
    Those should start you off in the right direction.
  5. so i'd have to know exatly where each deleted scene goes into the movie, and go put each in manually? that will take a while. i guess if thats the only way to do it its better than nothing.
    Apr 2002
    Australia
    If the deleted scenes are included in the movie as seamless branches then you should be able to use something like DVDx to convert to VCD with the extras included.
    If they are in a seperate menu, i.e. not linked into the movie, then you have no option but to paste them in yourself.
    "Weekends don't count unless you spend them doing something completely pointless."
    Bartman 8)
  7. it would be great to view the deleted scenes with the movie, but this movie has the bonus material on a 2nd dvd, so its not connected to the movie. so i guess this is gonna be really really hard to do.
