  1. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    I just recieved my batch today and burned my first one. I have been using TDK but decided to try BeAll's because on Meritline site it says that they are compatible with XBOX. But when I placed it in my XBOX it stated that it does not recognize the media.
    So, what I am asking is "Has anyone had sucess with burning BeAll DVD-R and playing them in a XBOX?" If so, what burning program did you use?
    Thanks,
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  2. sounds like your xbox is not modified?
    or is it?
    people may hate me for this, but ive found that princos work the best in the xbox's... ive tried in at leat 20 xbox's all with different drives (thompson, philips, and samsung)
    go figure
  3. Member SLICK RICK's Avatar
    Mar 2003
    I did not know it had to be modified to play DVDR's, I know that my PS2 play them with no modification.
    SLICK RICK
  4. are you burning x-box games or dvd movies?
    If you are burning movies, which i think you are, then make sure to burn the movie in UDF 1.02 format. You can do this in Nero by choosing Data DVD and choosing the format to be UDF 1.02. In fact I think that there is a button on the page that says make dvd x-box compatible. Good Luck.
  5. Member SLICK RICK's Avatar
    Mar 2003
    Yes, I am burning movies. I give that a try and post the results.
    Thanks,
    SLICK RICK
