After you have captured the video from either tv or comcroder and its a mpeg file, how do you convert it to dvd fromat?? Burned the mpeg file to straight cd and plays on DVD player but quality is real bad.
Are you talking about MPEG1 or 2? It sounds like MPEG1 if your talking CD. If so, a VCD is not the highest resolution and in most instances will look like garbage if you're not real careful in the capture and encode.
YOu might want to bump up to SVCD or DVD and encoding to an MPEG2 compliant resolution. -
Originally Posted by redvetter00
Now, if you can capture at a higher resolution than VCD like either 352x480 (1/2 DVD) or 720x480 (NTSC DVD) in mpeg2 format, then you can author and burn these files straight to dvd and get much better quality. Check out the "Author" section for creating a DVD from your mpegs."Art is making something out of nothing and selling it." - Frank Zappa
Combine Mpeg-2 Files (without re-encoding or loss of quality)
By Anonymous642 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2011, 06:58 -
Render MPEG-2 for DVD - How to improve quality?
By tripecac in forum EditingReplies: 40Last Post: 16th Jul 2008, 10:26 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24 -
how to convert these files to best quality mpeg?
By curt1sw in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 16:43 -
Saving files in original quality in MPEG Video Wizard DVD
By guy24s in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2007, 16:30
