so this is weird, on some of the dvds i create the program works like a charm. on others, when i try and play it on my dvd player it comes in black and white and flickers on the screen so you can't really see the picture.
this has happened more than once with different svcd's. it is weird because some work fine, and i never get any errors, etc.
anyone experience this before or have any suggestions??
Thanks in advance.
are you creating PAL dvdrs and your player plays only NTSC?
i was actually just looking into that. and i believe that could be the problem. would that cause what is happening?
is there a way to convert pal to ntsc without any quality loss??
thanks -
It would exhibt these issues. As for conversion lots of posts in the forum & others on dvdhelp. heres one
https://www.videohelp.com/forum/viewtopic.php?t=164771SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Weird problem with homemade DVD
By euroboy in forum Authoring (DVD)Replies: 12Last Post: 31st May 2011, 19:49 -
AVI on DVD/DivX- player, weird problem
By baranjac123 in forum Newbie / General discussionsReplies: 19Last Post: 23rd Mar 2011, 11:55 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
Subtitle timing problem, DVD created using DVD Flick
By Vianty in forum Authoring (DVD)Replies: 8Last Post: 28th Apr 2010, 03:33 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 13:50
