Hi,
I am looking for guide to backup a disc that has 2 angles. I want to keep one angle + everthing else.
Basically it is a full disc minus 1 angle.
-A4
This is very easy to do in IFOEdit. Rip all of the files for the DVD onto your hard drive and put them in a VIDEO_TS dir. Open the ifo for you movie in IfoEdit and hit Vob Extras down at the bottom. Set a destination dir (anything but your VIDEO_TS dir) and under Angles check Remove Angles and select the angle you want to keep. Hit OK and on the next screen hit Strip It. Let IFOEdit do its thing and then take all of the files it creates and copy them over to your original VIDEO_TS dir, overwriting the old files. Now for good measure open the VIDEO_TS.ifo into IFOEDit and hit Get VTS Sectors down at the bottom, just to make sure everything gets updated.
I have the same problem. I will definitely give this a try. I wonder if this method will also remove the angle logo on the screen when the DVD is played?
Strip Extras?
By Cabal2000 in forum Blu-ray RippingReplies: 1Last Post: 6th Mar 2009, 06:51 -
How to Strip Audio from an AVI?
By MadisonMax in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 12:53 -
Windows utilities to strip Javascript?
By Ai Haibara in forum ComputerReplies: 12Last Post: 22nd Sep 2007, 19:37 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
Strip out 2nd mp3 audio
By philanderer in forum AudioReplies: 2Last Post: 13th Jun 2007, 03:58
