  1. hi im about to Put a 2 file dvd onto a dvdr but making it so its 1 seperate file (Nerovision) i am wondering if i require the corect codecs like xvid etc or will the dvdr software do it itself?
    thanx
    May 2002
    leeds
    bit vague m8 but if the files are avi files then you need to convert them to compliant dvd mpegs or one mpeg if its two parts of 1 file
    use gspot from the tools section to check the codecs and convert when installed
    check out the guides section on the left colomb
    whats that your reading hope its work (s**t caught again)
