Ok, I downloaded a film in Divx, these are its properties...
512 x 384, 24 Bits, 126571 Frames, 23.976 Frames/Sec, 136 KB/Sec, DIVXMPG4 V3
I have encoded it to VCD using TMPEG, but there is no sound, I have absolutely no idea why?
The Divx plays fine, sound and picture are perfect. The picture encodes perfect too, but there is no sound at all. I have used the PAL template and so everything should be ok.
I have even re-built the divx by using divxfix, that still doesn't work. The preview in the settings/advanced/audio has no sound coming through either.
Any ideas as this has never happened before.
Thanks alot!
Gray
When you load the DivX in TMPGenc does it load into BOTH the input video & the input audio?
I would extract the audio from the DivX w/ Virtual Dub. Then use tooLame or TMPGenc to encode just the audio to MP2. Then encode just the video w/ TMPGenc to M1V (or M2V). Then mux them with bbMPEG. -
The movie you have downloaded is a new Mpeg 4, V3
TMPGEnc will need to work overtime to convert one of those, but can do it. However if its not working then load the AVI in and re-save to the DivX Mpeg 4, this is much better to work with. If you want to keep those AVI's as backup its worth doing it. You will also need to do this if there are any bad frames, as Vdub dont like them either
letmein...
The AVI won't load up, how do you when you say to load it in and then resave it to make it easier to work with?
Thanks!
Gray -
When you say it wont load into Vdub, is this becuase you dont have the codec on your system ?
What is the error ?
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 05:31 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 09:23 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 15:17 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27
