Just went through a lot of "fun" figuring out how to use TMPGEnc to reencode an AVI to be a compliant MPEG2 file for burning to a DVD using MF2 (which was MUCH faster than asking MF2 to do it).
My concern is that when the thirty-day "trial" runs out I'm going to have to find another tool to do the same thing. I know about the Pro product, but my budget is still recovering from purchasing MF2 and the DVD Burner (which came with it's own software that tends to freeze up). While MF2 works fine if you don't have to rencode your source, it is very slow if you do.
Any suggestions?
Results 1 to 11 of 11
You have been using the best tool avilable but if you can't aford to buy it go to the tools section and look under video encoders. There are many tools that offer demo versions. Main Concept is a good one. ..... harrymj3
Re-set it
I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
i hope your advocating clearing the registery and then installing the app in the future then returning the date back to normall jeez what next 8)
whats that your reading hope its work (s**t caught again) -
8)
I gotta admit I've done some pretty weird things in the past in order to avoid buying demo software, but it never occured to me to install it with the date set in the future. Ah yes ... nimble minds at work here ...
Anyway, I agree with buying TMPGEnc in this case (which is what I did). It's a great tool and not a bad price.The shortest sentence is said to be "I am". The longest is "I do". -
if you had a copy of the old tmpeg 12a, that whould be grate.
it doesnt have a limitation on the mpeg2.
i have it and it works pretty much the same.
(a bit slower, and a few things has changed, few things got better).
good thing i downloaded it back than...when it was free...
darn shame you dont have it, it whould have solved your problem
oh well.. you cant win them all.HELL AINT A BAD PLACE TO BE
SVCD2DVD crashes, HDTV2DVD runs ok
By silicon101 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 16:32 -
Video runs locally but not when downloaded
By Esinem in forum Video ConversionReplies: 4Last Post: 6th Oct 2009, 23:48 -
Fantastic, runs on Windows 7 64-bit!!!
By RealJB in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2009, 11:34 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 23:34 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 18:45
