hey i just bought NEC ND1300A X4 Speed from www.bigpockets.co.uk
i was wondering it didnt come with any cables or anything so are the cables actcullaly in the computer itslef or do i have tp buy some cables or is it ready to install??
thanks for help cause my dad being a total ass thinking ive wasted money on it
anyway thanks for comments later
joe
Staind // 14 Shades Of Grey // Buy It
You connect it similiar as a cd-rom. You may need a extra ide cable(if you only have one and it is already in use).
http://www6.tomshardware.com/howto/20020904/diy-10.html -
lol@your dad, you should be in luck. That is awfully cheap of NEC not to include any IDE Cables but what you need to do (hopefully) is you can slave your DVD burner off of your hard drive or cd-drive. There should be on a standard IDE cable three connectors on it. One goes into the motherboard. Then there two others which are usually closer in range. Just plug one of the emtpy ones into the back of your DVD drive. Then you need to connect the power connection to it. Those are the yellow red black cables. Good luck!
hey thanks for your replys this is what ive done so far ive installed the dvd writer but now i have a problem how much spare space do i have to have on my pc for this drive cause every time i turn on my pc and log on it comes up a blue screen with writing saying might not have a enoigh space and starts saying shit about "bios" opr some thing it say if this is your first time seeing this then restart or its because you dont have enough space .
anyway thanks if somebody could tell me where im going wrong that would be great by telling me how much space i need that would be cool thanks
#later
joeStaind // 14 Shades Of Grey // Buy It
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 11:05 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
Installing RAM
By Nitro89 in forum ComputerReplies: 32Last Post: 5th Mar 2008, 11:27 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 07:13
