OK, so I just made my first motion menu in Adobe Premiere and I want to add an overlay for authoring in DVDMaestro.
I exported from Premiere to mpeg-2 with CCE plug-in.
How can I capture a frame from my mpeg-2 file that I can open in Photoshop in order to use as a template for an overlay?
In the past, this was no big deal because my still menus were created entirely in Photoshop.
Any suggestions? Thanks!
Here's an update:
I've found a better way to do this.
1. Demux the mpeg 2 file in TMPGEnc.
2. Open the resulting m2v file in DVD2AVI and save project as d2v.
3. Create a "fake" avi file with VFAPI reader or create an avs file with Avisynth.
4. Open your avi or avs file in Virtualdub.
5. Hit Ctrl-1 to copy frame to clipboard.
6. Open Photoshop. Hit Ctrl-N, Enter, then Ctrl-V.
The advantage is that you can more easily find specific frames in the movie because of the ability to "scrub" using the timeline ruler in Virtualdub. Also the correct aspect ratio is maintained, eliminating the need to correct in Photoshop. The only disadvantage is that the resulting still image appears interlaced. This is easily corrected in Photoshop by running the De-interlace filter (Filter>Video>De-interlace). -
Yes, this is also a way to do what you want (albeit, a little more involved). In PowerDVD, you can also step through the frames, and capture at will.
For the interlaced issue, use the VIDEO > FORCE FILM option in DVD2AVI. This will get rid of the lines, unless your original video was hard telecined.
You can also export a number of bitmaps of your video using VirtualDub (but this can easily get out of hand).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by mtgoatI mean it in the nicest way.
You should be able to open the mpeg2 directly in VirtualdubMod . In other words, Jump to step 4 when using VdubMod.
Thanks All!
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
One subpicture overlay across menu cells? - DVDLab Pro
By nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 10:36 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
Motion Menu's - Where Do I Start? In Photoshop?
By EViS in forum Authoring (DVD)Replies: 11Last Post: 21st Aug 2008, 22:35 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01
