I'm able to burn VCD's fine with EZ CD Creator 5 Platinum. Can I burn SVCD's with it? If not, what should I get? I've seen a lot of posts mentioning Nero, is that the way to go? Please be specific with what I need. I don't want to spend a fortune, I just want to capture family movies (using ATI AllinWonder Radeon) and put them on SVCDs.
Thanks!!!
EZCD does not support SVCD. I us Nero to burn SVCDs. I didn't spend any money on Nero I downloaded the demo and then found a crack for the registery, but if you want to spend the money buy Nero it is great.
<font size=-1>[ This Message was edited by: PimpInDaHouse on 2001-10-01 13:54:25 ]</font> -
if you realy want to use easy cd
u can make your image files with iauthor svcd
then burn with easycd
NEWBIE Burn HD DVD
By Wally 2007 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 20:10 -
newbie,i have a problem,i burn a dvd on playback i get stutter when panning
By goldenbhoy in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2008, 14:00 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
Newbie Question: Can I use Alcohol default settings to burn DVD-5?
By ShadowRider in forum DVD RippingReplies: 1Last Post: 11th Aug 2007, 14:56
