I want to create a Video CD with CD audio that will play the video and the CD audio in a DVD player, also play the CD audio tracks in a CD player as well as a computer CD player and play the video portion of the CD in a computer. Is this possible and how do I create such a CD?
Thanks,
David
David
There was another post about this exact same question where someone found the answer to it. I can't remember where it was though so I'll try find it for you.
I couldn't remember the name of the post so I couldn't find it, but I've gone one better and found you a guide for it:
https://www.videohelp.com/forum/userguides/113432.php
Hope this helps you out. -
Thanks for the quick reply. The link you forwarded is the same as writing a CD Extra. The CD audio plays in a DVD player but the DVD player will not allow me to go to the video portion of the disc. I need to know if there is way to write CD audio and video on the same disc that will allow me to play either the CD audio or video when I choose to on a DVD player?
Thanks,
DavidDavid -
I'm sorry, but I don't know how to make a VCD in that way, although you will be able to because DVD players can natively play audio CDs.
If you look through the guides or try a forum search you may find your answer, although you probably already tried those options. -
You can feed TMPGEnc diff video and audio, to you could give it a video clip, or still as your video source, and an mp2/3/wav for the audio. downside is, you have to make an MPEG-1 Video/Audio file, so you cant fit as much on a CD, then if you only had MP2's and no video.
I Played with this once, didnt really seem worth it IMO.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Originally Posted by David Pell
As to your question, the answer is no. How your player deals with such discs is dependent on the player.
Regards.Michael Tam
w: Morsels of Evidence
Authored DVD plays 3 seconds audio/No video
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 6th Jan 2011, 14:26 -
Video Noob - how to create dvd for dvd player from avi, flv files..?
By acegap in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 07:10 -
I want to create video & photos on a DVD and play it on a DVD player
By samoyed in forum Authoring (DVD)Replies: 8Last Post: 14th Jan 2009, 00:27 -
Question about which AVI type in Total Video Converter plays in DVD player
By jimdagys in forum Video ConversionReplies: 2Last Post: 22nd May 2008, 07:37 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 12:39
