Hello
I have the following problem
I have recorded a VHS-tape(1.5 hours) and would like to make a DVD-movie of it.
My capture-card is a Hauppauge PVR250.
Normally capturing a VHS-recording to DVD (MPEG2) is no problem but .....
If there is a small disturbance in the VHS-recording, the captured DVD(MPEG2)-file will be devided in a first part (before the disturbance) where the audio/video is in-sync and a last part (after the disturbance) where audio/video is Outofsync (maybe by 0.5-1 sec through the whole rest of the movie)
A solution would be:
1) Cut the captured DVD(MPEG2)-file in 2 files with MPG-VCR(first part that is ok and last part that is Outofsync)
2) demux audio and video from the last faulty outofsync-file (what SW/how?)
3) Cut/add 0.5-1 sec to this audiofile to correct the audio (What SW/how?)
4) Merge the video-part of point 2 and corrected audiopart (What SW/how?)
5) Merge the first part(file) of the DVD-capture that had no synproblems with the corrected last part(file) into one file with MPG-VCR.
I am interested only in the DVD (MPEG2) solution
We have: FILE.MPG MPEG2 with MP2 audio out of sync
We want: FILE2.MPG MPEG2 with MP2 audio in sync.
Open FILE.MPG in Vdub(MPEG)
Adjust audio delay until sync OK (Audio-> Interleaving -> Delay... )
Start frameserver ( make xxx.vdr )
Open xxx.vdr with TMPGenc Set Stream type -> Audio only
Encode to xxx.mp2
Multiplex FILE.MPG (video) and xxx.MP2 (audio) to FILE2.MPG
done -
Forgot to say you should set audio encoding parameters to same as source.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
