i got my hands on what are french vhs tapes but when i play them on my video recorder( which is ntsc compatible)the picture is in black and white, is this an other knid of vhs tape or just that these ones are messed up, any help at all would be greatly appreciated![]()
The French tapes are PAL (720x576 @ 25fps), your NTSC system (720x480 @ 29.97fps) can't play them. You'll need to track down a PAL VCR.
sorry, man, my vcr is PAL, it just also plays MTSC on the side, ity must be faulty tapes, ah well, c'est la vie, thanks for taking the time to reply
I was under the impression that the French video standard is SECAM. Perhaps you should buy yet another VCR and TV.
House de Kris, you are right, i suppose its buy another video or suffer the black and white picture, thanks once again fo being so helpful
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
