Marty,
I have followed your seemingly GREAT tutorial to the letter. But when I get to the step where you are supposed to double-click on your MPEG file to bring up the Chapters tab, I get an error message:
"ist kein gultiger Gleitkommawert.
Any ideas? Thanks!
Ed
Results 31 to 60 of 166
hey, thank you
and i believe the error comes a couple of things
if you have the Enable Media Player on Chapter-tab
or the Enable VFAPI-avi for menu work box checked off in the settings tab, and you do not load the VFAPI-avi when it askes you (after you load the mpg) you will get this error...if you are following my guide, and are not using the menu generator to make your menus, then dont worry about the error.
to see if this is the case, CHECK THOSE TWO BOXES, then go to the menu tab, click on your mpg....after you get the error, just say yes, or continue, whatever it says....it should take you tot he chapter tab
go back to the SETTINGS tab and see if the boxes automatically unchecked themselves, if they did, then dont worry...go ahead with what you are doing, follow the rest and everything should be ok
if the problem persists, go to the ttool site....ask someone there translate the error
im going to be outta town for the next 4 days, so i hope this helps
i am also coming out with a guide for motion menus, hopefully to be done by today
1
marty -
motion menus guide is DONE...CHECK IT OUT!!!
http://www.personal.psu.edu/users/r/d/rdm186/guide2
1
marty
ps.... NEODAGO....GO AHEAD!! -
Marty,
I have followed your guide completely and successfully created the BIN/CUE files. However, when I loaded the CUE file in Nero5.5 and checked the File info, it gave me 4 tracks with a file size of 490MB each (the size of my original Mpeg movie). And of course Nero would not burn it because 1960MB would not fit on a 750MB CDR. Am I missing something here? Any help is very much appreciated. -
I bet you are using nero 5.5.4.0. this version is crap - it does not read the cue file properly. Try load the bin file and select dao or better still like I did, go back to version 5.5.3.5. I you don't want to use nero, cdrwin / fireburner are good alternatives.
That's right I'm using Nero 5540. OK, I'll go back to 5535 and test again. Thanks for the help.
<font size=-1>[ This Message was edited by: pelles on 2001-10-06 08:36:55 ]</font> -
I followed your tutorial, but I always get this error with my chapter index menu when generating cue/bin.
Starting VCDxBuild process...
D:\derek\tscv\TSCV.xml:166: validity error: Syntax of value for attribute ref on select is not valid
<select ref="D:\derek\chapmenu1.mpg"/>
D:\derek\tscv\TSCV.xml:267: validity error: IDREF attribute ref reference an unknown ID "D:\derek\chapmenu1.mpg"
parsing file `D:\derek\tscv\TSCV.xml' failed
VCDxBuild finished
This always happens with the second menu, seemingly no matter what. Can anyone please help? -
unfortunately, i have no idea what half the errors mean in that program....i am unfamiliar with xml and german...so when it comes to this shit...i have no idea
your best bet is going to
http://www.ttool.de
and emailing ttool himself, he will be able to tell you in no time
sorry
1
marty -
VCDxBuild finished
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I believe TTool said that was a bug in the latest release and that he has fixed it in the realease that will come in a few days. it has something to do with not finding the first chapter. -
I have successfully burned the CUE file using Nero5.5.3.5
Looks great but how do you make it to Autoplay? I have to press the Previous button once to go to the Mainmenu. And the second menu (chapter index) has a time limit of 5 sec and after that plays the first chapter automatically. When I press the Stop button on any chapter, it does not go back to the second menu (Chapter index), it goes to the blue screen on my TV. It should return me back to the Chapter index menu I suppose. But pressing the Previous button returns me back to the Main menu. Any help is appreciated. -
www.ttool.de
sorry
1
marty
yeah i kept getting bloody german errors, and it was pissing me off, so i went to
babelfish.altavista.com
and typed the error there, and selected translate from german to english. in the translation, the only part i could make out was something about illegal floating point decimal. i guess that helped abit. -
if you are making your motion menu or using the menu generator that may be the error that your getting (what sunmiztres said)
when i was making my motion menus, i had that problem where if i didnt chose to show the first chatper, i get an error (dont know if its the same). ttool was nice enough to send me a different copy that fixed it...should be out in a little
however im not sure if this is it, if it is...then youll just have to wait...if not...then i dont know
dont know if i helped
1
marty -
<font size=-1>[ This Message was edited by: Heheheheboi on 2001-10-08 08:56:18 ]</font> -
i have a problem in the menu creation everythin i add in the cd in menu tab on tscv then it ask open vfapi\avi what that mean???? then i cancel it then i continue with the step and made the cue and burn but when i burn it with adaptec and nero and cdrwin and fireburner it show up nuttin on the cd and i try converting it to mpeg and then burn it it only show up the movie but none of the menu or nuttin PLEASE HELP ME ????
[quote]
I had the same problem !! all I done was to untick the DISABLE Enable VFAPI-AVI FOR MENU-WORK.
You will find this on the setup tab.
PS I also had loads of problems with menus not working correctly, I traced this to my old CRDRW's being scratched.... worked ok on data & audio but give me lots of VERY strange errors on VCD's XVCD's SVCD's & XSVCD's.
Took me weeks to find out what was going on hope this helps
when it asks you for the avi that is when you are trying to make the motion menu using vfapi. using vfapi helps alot when you are having rpoblems with just the media player. when it asks you for the avi find the avi you created with vfapi unless you are skipping that step.
follow the guide 100% and you can't go wrong.
<font size=-1>[ This Message was edited by: sunmiztres on 2001-10-08 07:46:44 ]</font> -
ok...if you happen to have the first chapter "not shown" in your matrix then it is definitly what sunmiztres said
i had the same problem...but ttool let me try somethin to see if it worked and it did
when he lets out the new release it will fix it
if you dont have the first chapter not shown...then i dont know what it is
sorry bout this one
1
marty -
I'm interested in learning how to put menu's and chapters on a VCD also but I am not useing the same software that most of ya'll are like TMPGENC and so on. So far I have had good sucess using VideoWave 4.0 to edit and encode to Mpeg 1 VCD format and I'm using CD Extreme burning software. What I'm wondering is if there's a way that I could be sure to substuite my software names into your instructions on doing this. I appreciate the time you took to post this tutorial but I'm not familiar enough with the programs you used to understand where to substuite in the ones I use. Would it maybe be possible to put ( ) around the software names that are interchangable if they are interchangable? Just a thought, Thanks, Questor569
im a basically new at this stuff...ive only been doin it for a year...im only 19 so i havent been around it for too long
from the start ive been using tmpgenc, i have no idea how to use those programs that you use so i would have no way to let you know
the programs listed...tmpgenc, tscv, virtualdub, vfapi, and vcdimager are wonderful programs
this is the only way i know how to do menus....you can use whatever you want in the beginning to create your mpg but after that, you should give these a shot
you dont have to be a master at any of them....but you need like 1 or 2 things from each to get the job done
its really not hard and they are all freeware...you should give it a shot
im still waiting for the universal ripping, converting and menu making program....
give it a shot
1
marty -
the site is different..i have the motion menus and stills now
1
marty -
I followed the directions on the site and everything was great...I just have a problem when it tries to create the bin/cue. Does anyone know what this means???
I copied the mpeg off the vcd so I could try and make another vcd out of it with menu's. I am using tscv .74 and also tried .73.
Here is the output I get when I try to create me bin/cue. It seems to get through the menu's, but screws up on the mpeg movie file.
"mpeg scan: pack header code (0x000001ba) expected, but 0x52494646 found (buflen = 2324)
...this looks like a RIFF header but a plain multiplexed program stream was required.
input mpeg stream has been deemed invalid -- aborting " -
I really don't know exactly what that means but try demuxing and then mux with bbmpeg and see if that helps. -
Thanks a Million for the guide! I have waited months for someone to give a good explanation on how to use this program. THANKS!!!
all of this has been really use useful, so thanks a million. by the way, i used nero 5.5.4.0 and it worked just fine... actually, nero worked and cdrwin didn't go figure. but i had a question. is it possible to make a menu item link to another VCD? i have a ten part series (10 hours) and i wanna interlink em all... anything you know about this would be a great help... thanks
tim
"When you find yourself on the side of majority, it's time to pause, and reconsider your position." -Mark Twain -
cycletron --- thanks, anytime
tbambino --- i do think thats next to impossible...im working on the sopranos series....really dont see how you could link them together --- i just have a 5 disc dvd player so if i watch more than 1 episode, i just let it automatically change discs
other than that...you got me
1
marty -
tim
when you say link togther what do you mean? You could put a extro saying insert the next disk in that series. YOu could put a menu at the end with a chapter off of each disk so you know what part is on what disk. If that's what you mean by linking them together then yes it can be done. -
@Sumiztres
have you gotten intro and extro mpgs working?
i cant get them to show up when the vcd's are burned
i am also havein problems getting my backround bmp to show up on my motion menus
any clue
thank you
1
marty
On 2001-10-11 13:21:24, martymizah wrote:
@Sumiztres
any clue
thank you
1
marty
yes intros and extros work great for me.
when you say you can't get them tom work for you do you mean that when you insert the disk it automatically goes to the menu? Do they work on your computer? I have never had a problem with intros or extros. I know alot of people report that the extro never shows up but when i had that problem ttool told me to put extro as my default for the mpeg and all the chapters within the mpeg and when i did that it worked. how many mpegs are you putting on 1 disk? you might have to put extro for all chapters and mpegs. I don't know if that will affect anything else though.
your backfground menu is not showing up? Hmmm. is this with a still or motion? i have never had a problem with a motion but sometimes when i would add a still and then patch it, it would be black. i really don't know what was causing it but it was some kind of overlay problem. i would usually restart the computer and then do nothing but patch it and it would work so i am guessing there was some kind of codec conflict of some sort.
is virtualdub still running when you are doing this? If so try it without. Don't have any other media software running when doing this. HOpefully this will help if not report back or email me.
Menus & Chapters Multiavchd
By funkyirishman in forum Authoring (Blu-ray)Replies: 4Last Post: 30th Dec 2011, 11:08 -
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 02:11 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
Help with what software is good for menus and chapters
By shashgo in forum Authoring (DVD)Replies: 9Last Post: 3rd Jan 2009, 17:09 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 15:41
