Page 3 of 6
FirstFirst 1 2 3 4 5 ... LastLast
Results 61 to 90 of 166
    Jun 2001
    Israel
    Thanks for the wonderfull guide, clear and easy to use.
    I did evrything according to Marty's guide but when I try to create bin/cue I got the following:
    Starting VCDxBuild process...
    D:\TSCV\TSCV.xml:33: error: xmlParseEntityRef: no name
    <sequence-item src="D:\Burn\Slovakia & Czech_F.mpg" id="sequence-1">
    parsing file `D:\TSCV\TSCV.xml' failed
    VCDxBuild finished
    has anybody some idea why?
  2. Nice tutorial ... I had to change it a bit to accomodate 3 separate mpgs instead of one big one w/ chapters (I think I set my chapters up right hehe).
    Problem is, after I create the bin/cue and use daemontools to mount the image as a virtual cd (hah) and try to play in powerDVD it errors w/ a display problem...I had it all working once, w/ my menus on my chapter list workin (the main menu didn't).
    I must have done this 20 times in the last day or so and they play individually (wmp, the csv player) ... anyone else got the display mode error?
  3. use nero or cdrado
    never even heard of daemontools
    just follow the burn bin tutorial under authoring on this website
    <---------- over there
    lemme know
    1
    marty
    Jun 2001
    Israel
    marty
    have any idea about the failure described in my previous post?
    in one of your latest guides you show to use mpeg2decoder and mpeg2parser.
    were can i got them and what is the need for.
  5. With this kind of error, You may try to change the filename without blank and &.
  6. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2001-10-12 14:27:51, martymizah wrote:
    use nero or cdrado
    lemme know
    1
    marty
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    daemontools allows you to mount cue files (among other things). Its a virtual cdrom drive with the cue file from TSCV as the cd. But I figured out my problem w/ TSCV (The menu mpg was encoded wrong). Now, if I can get the mpegs to follow each other instead of going back to the chapter list I'd be set (making cartoon vcds, and it'll finish one mpg and go back to the chapter menu).
    Jun 2001
    Israel
    I got a final bin/cue file (several options)but can not burn it, it's burning but no visble output no thruough POWERDVD in the PC no standalone DVD
    No NERO 5.5.4.0
    No Nero 5.5.3.5
    No Fireburner (DAO96)
    No CDRWIN (demo version speed x1)
    Usual VCD's I burn with NERO successfuly.
    Has somebody burned, with what software.
  8. Ok i need somehelp please.
    in the STILL MENU GUIDE it says to make a quite 5 sec blank clip. How to do this and what does it do? and if you have one can you please upload it to a site and post a link please?
  9. done
    go back and check
    oh...and you need the audio to be blank because it loops over and over...you can put in whatever audio you feel like but itll get annoying if it just kept playing non stop
    thats all
  10. sorry need help again . ok i am finish making my menus and chapters but the bin and cue does not apear anywhere. this is what it says ,
    empty element??
    empty element??
    empty element??
    initializing libvcd 0.7.10 [cygwin/i686]
    this is the UNSTABLE development branch!
    use only if you know what you are doing
    see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    front margin set smaller than recommended (0
    rear margin set smaller than recommended (0
    <log level="error">raw mode2 file must have size multiple of 2336
    </log>
    VCDxBuild finished
    thx
  11. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    use nero or cdrado
    lemme know
    1
    marty
    Marty thanks for the tutorial. Great job.
    I find tvsc a bit strange to work with so your tutorial helped.
    Can you just explain to me about the second chapter Index page?
    how big is the image size or canvas size you used?
    Did you just create one large canvas and add in the different pics for the chapters? If so wouldnt that have to be a large bitmap that would not fit in tvsc ?
    also are the chapter pics clickable? Can you make them like that? That you can highlight the chapter and hit enter to play it?
    just curious. I am working on some chapters now.
    One more thing how did you do your pics? Did you capture them from an avi or mpeg? If so with what software?
    thanks again
    Dave
  12. both menus are the same size....
    i shrunk the images to fit them onto the menu
    no, they are not clickable but the keypad on the computer does work in place of numbers on the remote
    i actually used tscv to capture the pictures for that one, however, since then, i use capture express...its a program that allows you to do screenshots (how i make the guide) its free for download on download.com
    you can just open the movie in a dvd playing program, hit F11 when you find your shot...save it as a jpg and then modify it in any paint program
    its pretty easy and there are no glitches to work around
    try it, let me know
  13. whats wrong with tscv for me? anyone?
  14. hey, im back to square one here....
    i had tscv on my desktop and i accidentally deleted it, so now everything is messed up
    cant get it to work with motion menus anymore, i dont know whats up....
    as for you, i dont knwo what that error is, try emailin ttool...his address is on the http://www.ttool.de site
    you can try dloadin these, install them, see if it helps
    http://www.personal.psu.edu/users/r/d/rdm186/regdrop.zip
  15. been gettin alot of questions regarding the frameserving
    if you are having problems, please make sure that you have run the aux setup in virtual dub
    i have finally gotten mine to work without framserving, my trick was reformatting my hardrive, gettin rid of horrible ME and installin wind 2k
    you should try it
    haha
  16. Thanks Marty for the great job.
    I got a question hope that someone can help.
    I got everything working, Xing software and DVD player can play. But i can't open the mpeg file (not the menus) editing with any software. So far the editing sw that i have tried are ifilmEdit, myFlix, vcdCutter.
    Any help ????
  17. is the before you make the chapters of after
    let me know and ill try to help
  18. Member
    Portland, OR
    On 2001-10-05 12:17:09, martymizah wrote:
    hey, thank you
    and i believe the error comes a couple of things
    if you have the Enable Media Player on Chapter-tab
    or the Enable VFAPI-avi for menu work box checked off in the settings tab, and you do not load the VFAPI-avi when it askes you (after you load the mpg) you will get this error...if you are following my guide, and are not using the menu generator to make your menus, then dont worry about the error.
    to see if this is the case, CHECK THOSE TWO BOXES, then go to the menu tab, click on your mpg....after you get the error, just say yes, or continue, whatever it says....it should take you tot he chapter tab
    go back to the SETTINGS tab and see if the boxes automatically unchecked themselves, if they did, then dont worry...go ahead with what you are doing, follow the rest and everything should be ok
    if the problem persists, go to the ttool site....ask someone there translate the error
    im going to be outta town for the next 4 days, so i hope this helps
    i am also coming out with a guide for motion menus, hopefully to be done by today
    1
    marty
    I have Windows Media Player checked, but not VFAPI (I don't know what it is or how to use it.) I get this error, but when I click "OK" nothing happens. It just sits there on the menu tab and won't allow me to advance to the chapters tab, so I'm pretty effectively stuck.
    KSJ
  19. ok..that error you get it cuz you did not load a vfapi and you had the windows media box checked
    if you notice that after you get that error, if you go back to the settings menu, that box will no longer be checked
    if you are making still menus, dont worry, continue with the guide
    if you are making motion menus, you need to make a vfapi and load that when it prompts you (after you load the mpg) that is all covered in the motion menu guide
    see if this is it
    let me know
    Portland, OR
    see if this is it
    let me know
    Okay, I disabled media player and now I can get to the chapters tab, but once there, almost all of my options seem to be disabled and there's nothing in the viewer screen. I freehand entered the movielength per the instructions, but I want to hand set my chapter points, not have them set automatically ever so many seconds/minutes/frames. What am I missing here?
    KSJ
  21. I get a 404 when I try to download TSCV v0.73b rel2... where can I get it?
    If it's not available anywhere, could someone email the install to me? adam@tuttlepress.com
    _________________
    crap, i damned my pants again.
    <font size=-1>[ This Message was edited by: > ricochet < on 2001-10-20 17:18:44 ]</font>
  22. ftp://tscv:tscv@144.132.188.100:100/TSCV0741.zip
    theres an ftp that has it
    give it a try
    up for about 16hrs a day
  23. You can also get the newest release 0.74 release2 off of my ftp.
    ftp://tscv:ttool@65.208.195.148:21
  24. the new release is KEY get it it works beautifully as of now
  25. newer release of tscv....version 8...rel 1, available for download on sunmiztres' ftp
    many new features, multiple page motion menu creation, etc...works much better than any other release
  26. Yo, first off, thanks for the tutorial. I need some help though.
    I'm having trouble understanding what the stuff under that 'Chapters' tab does. Does it matter how many seconds I put in? I don't understand what it does to the VCD.
    Help is appreciated. Thank you.
  27. ok,
    the stuff under the "Chapters tab" is where you make your entrypoints
    it just puts points in your video file that allows you to skip to them either using the numbers on your keypad or the prev, next arrows....
    in the top couple boxes, where it says "chapter after" or "chapter every" is just that
    you can tell your program that you want a chapter after 30 seconds by typing 30 in that line and pressing enter...after the chapter is entered, the time (in seconds) will appear in the large white box on the bottom right
    you can enter as many chapters as you want, or none at all...its all up to you
    you can do it by frames, seconds, or minutes...
    also, what i do, because i find it much easier..is this
    when i rip the dvd, i have smartripper rip the *.info file....this file contains all the chapter times for the movie...if you do this, you can enter the times like this:
    when you get to the chapter tab, under import chapters from, click SmartRipper....then just find your info file that you ripped...this will automatically import all of you times into that big white box...
    as for the rest of that stuff (Cdi-size in...cdi...all that garbage on the right) dont worry about it, you dont need to know anything about it....
    i think thats about it...lemme know what other questions you have, ill get back to you as soon as i can
    lemme know
  28. Ahh. So if I'm understanding correctly...I don't need to skip to any certain point in a chapter. I am making a VCD out of a concert. So I don't think I'll need this.
    What I got out of that is that it will skip to that certain point which will be X seconds into the chapter if you tell it to.
    Correct me if I'm wrong.
  29. thats right, if all you want is a menu, then forget all that chapter stuff
    its kind of convienent to have...you should just do a chapter every 10 minutes or so, so if you stop the vcd, you dont have to start it from the beginning again
    but no, if you dont want, you dont have to have chapters to have a menu
    hope it helps
  30. My two cents:....A lot of people are having problems with Tsvc, I think this is agreat program for menus,
    I think the only problem is this program is too complicated due to the fact that it requires other programs
    to do its job,(vfapi, Tmpeg, ....). Since menus are individual mpeg files, I create them first using different
    programs with nice animation to create a final mpeg. after all my menus are created THEN I use TSCV to create
    the BIN/CUE file. And that is it. It does not matter what programs you use to create the final mpeg, as long as
    you have a working mpeg that you can use to burn a BIN/CUE. I wish there was a --simple-- LITE version of TSCV
    that would make the XML file and nothing else to avid confusion.
