when you chose the decode option in dvd2avi what bitrate does it make the wav?
When it's a Wav than a bitrate is not important, or what do you need it for?
Normally you only need this for compressed audio (Wavs are normally uncompressed audio e.g. 44 kHz, 16 bit ...)
-Steve56
<font size=-1>[ This Message was edited by: Steve56 on 2001-07-08 19:55:18 ]</font> -
heh...the .wav that i extracted w/ dvd2avi have ranged from 224 all the way to 484..i think..but it doesn't matter cuz tempgenc will compress that down to wutever u indicate..(224 kbits is SVCD standard, btw)
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
