I have readed in a forum that in one DVD can fit up to 6 hours of a movie.
Is that true? If so, in wich format (VCD, SVCD, DVD compliant ) must be the movie? with wich bitrate (Video and Audio) I have to conevrt it (or Capturate it)? Any help woul be very very apreciated. Thanks in advance.
If 6 hour then it would be about vcd quality,
352x240/288 (you can use higher resolutions but it will probably make it worse)
1497 kbit/s mpeg1 or mpeg2 video
192 kbit/s mpeg1 or ac3 audio
( www.dvdrhelp.com/calc )
you could also try a www.kvcd.net tmpgenc template if you are converting with tmpgenc. -
PAL DVD, 25 fr/sec, MPEG2
60 minutes, 720 x 576, Video data rate: Max. 8000 kbps
90 minutes, 720 x 576, Video data rate: Max. 6000 kbps
120 minutes, 720 x 576, Video data rate: Max. 4000 kbps
240 minutes, 352 x 576, Video data rate: Max. 2400 kbps
360 minutes, 352 x 288, Video data rate: Max. 1800 kbpsYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
How??? Even if I use no audio I get max about 1700 kbps.Originally Posted by tompika
Is there some reason why you cannot split your movie into two DVD's and put them in a dual case?
The quality of a 6 hour DVD would be horrible!Just what is this reality thing anyway? -
Thats what Movie Factory2 saysOriginally Posted by Baldrick
Isn't it correct?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 01:42 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 19:20 -
Maximum length of XLR cables
By Graham Archard in forum AudioReplies: 2Last Post: 3rd Apr 2008, 22:03 -
Maximum Length on a single layer DVDr
By acid_burn in forum Newbie / General discussionsReplies: 6Last Post: 16th Dec 2007, 06:05 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 22:55
