Page 3 of 3
FirstFirst 1 2 3
Results 61 to 76 of 76
  1. chris matey hi. how and where do i get this new svcd2dvd prog with the menus?
    kinda new to this he he
  2. If you got the svcd2dvdmpg+ version update manualy.. type your information and it will be on the page there.
    Greatings,
    Yf
  3. dvd_maniac
    Guest
    if i have a vcd mpg file with 48khz audio, can i use the skip re=sample step and have everything work fine.
  4. With the new version it will just skip the step even if you didn't select the skip option.
    Greatings,
    Yf
  5. Guest
    Hi chris
    looks like a cool update..............
    i have had to reformat........
    am i still eligible for this version m8?
    whats my serial?
    DOH!
    thanks
    KYUSS
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    KYUSS: yep sent it to you.
  7. Guest
    what just?
    which email addy m8?
    or do u mean originally "sent it to me"?
    cheers
    KYUSS
  8. Guest
    Should I uninstall SVCD2DVD+ before installing this new version?
  9. YES....
    the installation process will tell you too...
    Greatings,
    Yf
  10. Guest
    Along with the SVCD2DVD 1.5 upgrade (5,367 KB), I was also allowed to download the following files:
    SDEPatcher.zip (5 KB)
    MagicLibrary.zip (140 KB)
    AutoUpgrade.Lib.zip (9 KB)
    SVCD2DVDMPG+.zip (675 KB)
    What are they for? and where do I put them?
  11. These are updates..
    Just install SVCD2DVD 1.5 it will run auto update when you start the program. So you do need to download the updates manualy.
    Greatings,
    Yf
  12. Guest
    Originally Posted by yf2001usa
    These are updates..
    Greatings,
    Yf
    Did you mean "do" or "don't" need to download the updates manually.
  13. DON'T sorry typo..
  14. Guest
    thanks Yf! That worked.
    I've already burned 4 DVDs with this new version and the program has worked beautifully each time.
  15. DumpSite
    Guest
    What cam i say You are truly a dedicated Indivual . Hope you hit the big time.
  16. SVCD2DVD V1.5
    Guest
    Hi there every one can you tel me how much is it to buy this program and where i can buy it from ....As on the web site there is no way of buying it...
