I've having problems with the motion menu feature of DVD workshop.
I can only create 1 motion menu even though the option is selected on all menus. It also seems to last longer than the 1 sec duration i select.
Anybody else came across this?
Do you have the full version or are you still using the trial?
If you have done it before and now it won't, I would suggest reinstalling the program.
If you're having trouble with the necessary steps for creating motion menus, you might have a look at the tutorials.
1. Animated Menu Backgrounds:
http://www.ulead.com/learning/dws/dws_01_1.htm
2. Motion Buttons:
http://www.ulead.com/learning/dws/dws_02_1.htm
Jerry Jones
http://www.jonesgroup.net -
I had a lot of trouble with motion menus in DVDWS. I found two things causing problems: First, it seemed that the project got corrupted, so I had to re-create it.
The other problem was due to the fact that I was working with MPEGs rather than AVI files. Well, that wasn't really the problem. DVDWS will work fine with MPEGs if you replace a DLL that has a bug in it. See this thread for more info: https://www.videohelp.com/forum/viewtopic.php?t=172742&highlight=Thanks
Roger -
Thanks, reinstalling seems to have cured the problem.
I didn't realise DVD authoring was this troublesome
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Editing and replacing a motion menu problem
By kpic in forum Authoring (DVD)Replies: 4Last Post: 5th Aug 2010, 17:11 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 07:12 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 21:12
