SVCD2DVDMPG+ stops while converting the audio sample rate. I have tried this with three separate titles only to have it stop working on thr second CD on 2 titles and on the first CD on another. I was able to convert all to DVD_MPG using the regular version so I don't think I have bad Cds. I checked system performance and DR. Watson is around 54% processor use and MAPLAY.exe is at 36%. At first I thought it was still working and let it run for three hours and it never budged. I am using ver 1.0 build 1.0.1318.29595. Is there something I'm missing or not doing? Is any one else having this problem?
I'll send you a new build to see if this improves things. Check your email.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks Chris, I got it. Tried installing. I'll send you an email with specifics.
Ken -
RandalliserGuest
I was away for a week and this morning I took the update to the latest version and have the exact same problem as Cadiken.
It was working fine prior to this update.
Please advise -
Randalliser: cadiken is trying a new build & will report back his findings.
I tried the new build and it worked without fail. I was able to see the errors when they happened, it was when the program lost sync. The quality seems to be good since the VIDEO_TS folder files play well on the computer (haven't burned yet ). Thanks Chris this fixed my problem. Randalliser, if you are having the problem I was having this is the fix for you. Chris is this decoder going to be the included encoder in v1.5? I hope it is, I can't wait for the new progy.
I am also getting this hang when doing the resample.
Mind you, maybe this wont matter now?? as I have just read that hopefully a nice shiny new version (SVCD2DVD v1.5 preview) will be out sometime over the weekend?
Have fun
Graham
Starting (S)VCD2DVDMPG+: v1.0.1318.29595
Begin time: 07:12:24
############### New MPEG File ###############
File: D:\makedvd\New Folder\FILM1.MPG
Horizontal Res: 480
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
Need to resample PAL audio to NTSC audio. Is it possible?
By mob in forum AudioReplies: 8Last Post: 28th Jul 2013, 23:51 -
How to resample the audio of a WMV file ?
By turbo20010 in forum AudioReplies: 22Last Post: 13th Jan 2011, 13:21 -
let the standalone do the resize (resample)?
By rebl in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 15:46 -
Avisynth "ssrc resample audio" help
By DaneClark in forum Video ConversionReplies: 0Last Post: 11th Jul 2009, 00:50 -
Export frame resample (PAL HDV)
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Jul 2008, 16:07
