I haev two MPG files that total up to about 850MB. What can I convert them to, without losing quality, so that they will fit on a 700MB CD? And how do I convert them. I haev have Sonic Foundry Vegas Video 4.0C if that will work.
Thanks.
some options:
reduce the bitrate.
try VBR rather than CBR.
try reducing the bitrate of the audio if that is less important.
VV4 will handle all that, or use TMPGEnc
unfornately, to reduce something must disappear, and could well be quality, but you can try minimising the loss with the above options.
BTW, is is MPEG2 or MPEG1 and are you doing it just to fit on 1 CD ? or VCD/SVCD?
How to do this? Just render in VV4/TMPGEnc and select from the options. -
If you don't plan to author it, then make an XviD, no doubt the best solution. If you plan to author, you can make an 795MB file because (X)(S)VCD gets burnt in Mode 2 (800MB per 700MB disc), which doesn't have the error correction since the formats have their own (kinda).
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
best program for separating one large MPG file to several sequential files
By nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 17:09 -
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 05:59 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 21:43 -
Move OS from small hd to a large hd
By mysts in forum ComputerReplies: 8Last Post: 24th Feb 2008, 06:17
