    Apr 2003
    Michigan
    hi
    i use TMPGEnc to encode movies from AVI to VCD and latly evry movie i encode it gets longer by about three hours of just a black screen. please help
    P.S. thanks in advance
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Scan and remove bad frames, here's how.
  3. Downloaded divx movies??
    Another possibility is that the audio is encode with VBR. TmpGenc doesn't like this which causes this problem. To find out if this is the case, open the avi in virtualdub. If it warns about VBR audio, this is the problem.
    Two possible solutions.
    1) Use TmpGencs source range feature to stop the encode on the last (or last but one) frame.
    2) Use virtualdub or goldwave to extract the audio to an uncompressed wav file and use that as the audio source when you encode.
    Apr 2003
    Michigan
    thanks plenty guys but ethier of your ideas dont work
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Or change the directshow priorority
    www.dvdrhelp.com/tmpgenc#problems
