hello.
I got a pinnacle pctv pro and Im capturing music videos out of mtvand they look pretty good, but the picture quality is a little low, I mean, is good but I can see little dots all over,I was wondering if there is software or filter that will make the picture look more smooth ? I capture in avi format. thanks !!
Try VirtualDub.
Otherwise, it is always best to try and get the best from the source on the first get go if possible. -
video will not be better than the source it came from. for example if your source is vcd quality no matter what you do it won'y look any better than that.
Your problem is most likely due to analog noise (snow) in your picture. You can use any temporal, or spatial smoother to remove it. Contrary to what your reading, you can indeed improve on your capture by post processing.
AVISynth, or VirtualDub are pretty much the standard around here for free tools. They come with a rich filter set to do exactly what your looking for. Find them in the tools section. You can find additional filters here:
http://shelob.mordor.net/dgraft
http://www.avisynth.org
Their both a good starting point when looking for filters.Impossible to see the future is. The Dark Side clouds everything... -
Try boosting your signal level. 'Sparkles' mean you need another 5 - 10 db of signal level. Try an external decoder and send the composite/S-video to your capture card. Your computer is an incredibley noisey place for a TV signal to be. No internal capture card can ever capture an RF signal better than 'good'. 'Excellant' and 'DVD' quality requires an external reciever. This doesn't apply to composite/S-Video as it's already de-modualted.
Also make sure you are using real cables, not el-cheap audio cables in disguise. Also make sure everything is on the smae AC circuit, ground loops can adversely affect your capture (that includes cable/sattelite, reciever/demodualtor, and computer system).To Be, Or, Not To Be, That, Is The Gazorgan Plan
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 08:23 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 07:51 -
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 20:24 -
compress AVI file for future editing with minimal loss of quality
By samoyed in forum Newbie / General discussionsReplies: 4Last Post: 9th Feb 2009, 02:53 -
caputure analog video and encode from cam
By greendesert in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 29th Jun 2007, 12:01
