I have an SVCD that is not synced when I play it in my DVD player. I believe this is because the SVCD is encoded at 2500+ where its only supposed to be 2400 max (I suspect the author put 2400 max for video, so with the audio its more then 2400, i dont really know how that works).
Anyway, how can I go about downgrading the bitrate slightly to get it under 2400? I cant open the mpeg2 file in TMPGEnc (even though I have WinDVD installed). Is there another codec I need to open mpeg2s in TMPEnc?
hmm, i think I meant 2600 instead of 2400 (vcdeasy confuses me with its 2400 msg). 2600 is the standard (i think?). the file is actually (as analyzed by vcdeasy)
Video Stream: Motion Video, 480x576, 25fps (PAL), 2530kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 09:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 18:07 -
4:2:0 - more than one type of Cb Cr sampling direction ?
By Movie-Maker in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2008, 17:45 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 11:23
