I"v try"d vcdeasy to copy dvd to vcd but ittook hours to rip &encode do anybody know of a faster download please
Hey there . . .
This is my usual method for DVD ripping
1) rip dvd to hard drive using latest version of DVD-Decrypter (remembering to demux the require audio track to a seperate AC3 file). For a typical 80 minute movie, takes 13-16 minutes
2) convert AC3 track to WAV file with Headac3 - time is typically 4-7 minutes
3) use DVD2AVI to generate a D2V file for frameserving - time (with DVD2AVI set to 'no audio') about 5.5 minutes
4) write a one line AviSynth script that points to the D2V file and performs a bilinear resize to 352 x 288 (PAL VCD format)
5) user CCE to load the script from (4) - set the audio track to use the WAV file generated in step (2), and select the VCD template in CCE (also select the "ultra low bitrate" quantizer template). Encoding speed is normally 1.5 - 1.8 times 'realtime' - in other words, that typical 80 minute movie will encode to PAL VCD format in around 54-56 minutes, depending on what else the 'puter is doing.
SO - for that 80 minute movie, time taken from start to finish can be as quick as (13 + 4 + 5.5 + 54) = 76.5 minutes (approx) - not too shabby!
Cheers,
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 01:17 -
Faster DVD Authoring
By TheLaserdisc in forum Authoring (DVD)Replies: 9Last Post: 14th Dec 2008, 21:41 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
