Hello. I have an Ibook Graphite SE 466 Mhz and i am looking to buy a good dvd -r burner. My hubby has a PowerBook 867 Mhz G4 and i've been using it with CompUsa DVD-R media with success. But i want one for me. Is there anything out there or should i upgrade to a newer Mac. ? Kinda down in the dump, now that i found out imovie3 doesn't play in my ibook and can't even use imovie2 to capture my homevideos.Anyway.......TIA
i highly recommend a newer Mac, however it can be done on your current setup.
We currently use a Formac Devidion and it works well, but you should have NO problems with ANY firewire DVD Writer.
Just make sure your iBook is maxed out on RAM.
hope this helps.
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
What's a good external DVD burner for my iBook G4?
By KeepItSimple in forum MacReplies: 12Last Post: 12th Sep 2007, 10:08 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19 -
Problem with iBook G3 after ffmpegx usage
By AndyPanda in forum ffmpegX general discussionReplies: 3Last Post: 25th Jun 2007, 17:46
Anyway.......TIA
